JDM headlights Question
-Built harness for $20. You can save some time not making one.
http://evomoto.com/product_info.php?...98ce51ee3ab1d6
-Build your own $8 harness. Google "9006 ballast harness", you'll find a website that sells an unmodded 9006 harness for $8. You can build a more affordable one and get to use a drill and flathead screwdriver.
Both ways we help the economy.
Mods: If the above links isn't allowed. sorry, feel free to edit my post.
alright so the write is sweet cause i was able to get it all done up right.. thanka alot but i just notice that the amber bulb doesnt fit into the jdm headlights... do u know what type of bulb that is ... so i can get that all in thanks
jakc
jakc
Yes sir I am.
MIke
Jack: You have a 9006 bulb right? The bulb plug is at a 90degree angle, right? You have to install the bulb into the headlight first. Mine took some messing w/ to drop into the notches. Then you plug the harness in. It's harder if you try to put the bulb in w/ the harness connect. Hope that helps.
Yes sir I am.
MIke
Yes sir I am.
MIke
Yeah i got the fogs in .. i was talking about the bulbs for the turn singals??? the orange ones... yeah i couldnt read wat type they were so i figure u would know.. sorry about the confusion there.....
