Chipping front bumper mesh :/ Is there an annodized mesh out there?
I know the stock mesh is just painted on, cause mine is just flaking off like crazy. Is there a mesh out there that is an anodized aluminum so I dont have to worry about repainting the mesh and it chipping off again? A link would be great, thanks.
I ended up removing all the different mesh on the front bumper, soaked them in paint thinner to strip to bare metal, then resprayed it with primer, black base coat, then an extra clear coat. This proved to help from chipping, but if you travel at high speeds theres no coating that can protect it from chipping.
to the OP, powedercoating would be your best bet.
Leave it bare!!!
I like the paint thinner idea. What is wrong with leaving the mesh as bare metal without repainting, then you will not have to worry about it chipping. The mesh on my Seibon hood is bare metal initially. I think it will make the grill match the hood better.
1 Post
Sadly enough even a Type III anodize (hard coat) will chip off from rocks at high speeds. The anodize coating itself will not be penetrated... that is the bare aluminum won't be showing... so if you were looking for corrosion protection then you are golden... unfortunately you are looking for cosmetic. The black dye in the anodize is added after the coating goes on and is only a few thousandths of an inch thick.
Whoever mentioned powder coating may be on a better track for this kind of resistance, depending on the final layer... though even that will chip!!
The best solution I have found is a low maintenance approach to repairing the ****ty looking mesh.
I don't even bother to remove the mesh to repaint them... I mask off the bumper and use a "dry brush" technique to repaint my mesh grilles. (the hood vent mesh is a different story... easy to remove so I take it off)
To dry brush it, load your brush up with some black paint (find some good outdoor grade stuff at your local store) then you brush most of that paint off onto some cardboard (etc) so the brush is rather "dry." Then you just sort of "poke" at the mesh, lightly re-loading the brush each time. The key is to have VERY LITTLE paint on the brush so you get 0 drips/runs/etc. 2 coats and you're good to go.
