gauge placement
Old Mar 23, 2009 | 02:59 PM
GST Racer's Avatar
gauge placement
I want to get a wideband o2 sensor and gauge, and I'm having a hard time finding a spot to put the gauge. I want it in an area thats easy to see, but I dont REALLY want to have the a-pillar gauge pod. My boost gauge is on the steering column, and I dont want to put another gauge up there. So where do you guys put all your gauges?
Old Mar 23, 2009 | 03:37 PM
EvolNinja's Avatar
Some folks in here do this
Old Mar 23, 2009 | 03:51 PM
jxs1984's Avatar
maybe a rexpeed triple dash gauge pod
Old Mar 23, 2009 | 04:40 PM
RichC's Avatar
Originally Posted by EvolNinja
hah, why is that AFR gauge all crooked? Is that the cool thing to do? Do they drive with a "gangsta lean" and have to compensate for it?
Old Mar 23, 2009 | 05:15 PM
Houston_Evo8's Avatar
I have mine in the same location, only.. not so crooked
Old Mar 23, 2009 | 06:09 PM
Wht9er's Avatar
how many gauges do you plan on running? i just purchased the lower console triple gauge pod. its a little cheaper than the upper dash pod in that you don't have to purchase the radio relocation kit. The down side is you can only run 52mm gauges down there (that is the only hole size they make for the lower pod). But my setup will be a single pod on my a-pillar (wideband), 3 in the lower pod (boost, egt, oil pressure) and one fabricated to fit into my ashtray (meth flow).
Old Mar 23, 2009 | 06:22 PM
dbotkin5's Avatar
My personal favorite location. Pic from the old 8 and where I'll be putting them in my IX as well:
Old Mar 23, 2009 | 06:26 PM
randomevo's Avatar
^^^ thats where i have mine, though i'm feeling the gangsta lean ;-)
Old Mar 23, 2009 | 06:28 PM
Standing Z's Avatar
In the glove box if you want to be stealthy
Old Mar 23, 2009 | 06:30 PM
19DB794's Avatar
I have a Defi boost gauge and an AEM UEGO wideband on my steering column. The only thing they cover is the Lancer gauge and the speedo but only up to 30 MPH.
Old Mar 23, 2009 | 07:41 PM
DocCola's Avatar
similar to 19DB794 (Josh, since he did most of my installation) I have my boost and Uego on my colum pod. My gauges are spread out enough that I can see all of my gauges behind them. When I add more I'm going to replace the lower MR pod (since 2 or the three gauges down there are useless to me) and if I ever need more than that (doubtful to need 8 additional gauges) then I will do the rexspeed pod on the dash.
Heres a pic of my set up:
They are a bit more level and sorry the darker one is blurry, I was free handing it no flash in the cold, but you get the idea. I like the set up a lot, and I don't really like the ricer look at all of gauges all over the place.
Old Mar 23, 2009 | 07:44 PM
GST Racer's Avatar
lol. yeah my boost gauge is on the right side of the steering column covering the "lancer" spot. good ideas guys. i just saw where someone removed that lancer spot and put the wideband in there. I was thinking of doing that.
I was thinking I really only need a wideband and a boost gauge, but I realized I'd probably need an oil pressure gauge as well. its funny how the car has none what-so-ever.
Old Mar 23, 2009 | 07:53 PM
Epix_'s Avatar
That's the JDM angle.
Old Mar 23, 2009 | 08:06 PM
19DB794's Avatar
you really don't need to see the wideband all the time. You could just mount the boost and oil pressure on the steering column and have the wideband in the glove box. I'll probably get an Oil Pressure gauge soon but I need to find a mounting spot for it lol.
Old Mar 23, 2009 | 08:22 PM
DocCola's Avatar
the lancer guage can be done but I've heard its a royal PITA.
Quick Reply: gauge placement
