Greddy CounterWeight Shift Knob
I had heard of other users having this shift knob so i finally took the plunge and got one and obviously went about it all wrong and used ebay for starters. Secondly it only screws on a little ways its useable but frustratingly ugly and the sticker is upside down when tight. So my question is does anyone else have this shift knob and did it screw on ok for you? i went to lowes and found a nut and bolt that was its size and screwed it on and the threads inside the knob are far apart and the threads on my shifter are close so thats obviously the problem but WTF its marketed as evo product sry for the book
Registered User
u screwed it too much?
on my evo ix when i took off the shift knob and screwed it back on it was upside down to.
all you need to do is turn it back and little and use "thread lock" (solvent to help hold the threads in place).
If you take the knob off there is a hole all the way through put a screwdriver through it and then screw the knob on and place the sticker in the correct position. I put a rubber gromet in the boot and pulled it up over the bottum of the knob to hold the boot up high so it looked better.
no its real i mean its used as in the person used it and took it off his car and sold it to me i got the black and silver was already on it. i did what you said and jammed it off and just glued it back on correctly but theres still if i look down before i put the sticker on alot of thread it wont go anymore and it leaves a space to the boot is that normal?
Beardly P
Jun 10, 2013 09:00 AM
hytek369
14
Jun 26, 2008 12:13 PM
