My EVO on a Budget Truck Rental "Car Dolly"
I'm moving from NJ back home to FL at the end of May!!! My question is...do you think I can get my EVO on a car dolly?
The car is on Swift springs and about 1.5 inches lower.
I can't get the car to drive up on a set of Rino ramps to even change the oil so I'm a bit worried!
If you know...please chime in.
I picked up my 06 mr se and used a 4 wheel trailer from Uhaul and we had to use pieces of wood to get the angle right so the front end wouldn't scrape, and I am at stock ride height. I think you'd be better off removing the bumper or you're going to have to stack varying heights of boards. Also, the front edge of the trailer is raised so it may touch there also, once the car is completely on. Hope this helps.
Thanks guys
it really is pretty simple. is it really only six clips?? last i did it i took off like 15 clips and i think 6 bolts. 2 bolts in wheel well, 2 near IC and 2 by the top of the radiator. was i doing extra work by taking all those clips off, are there really only 6 that NEED to come off?
