weird rattle
Old Apr 10, 2009 | 08:52 AM
thee stig's Avatar
weird rattle
was leaving school yesterday and the car was making a weird rattle at lower rpms does not matter if clutch is in and sounds like an exhaust piece is loose was wondering if it should check some other things after i try to tighten the exhaust
Old Apr 10, 2009 | 08:56 AM
N3VO's Avatar
where was the rattle coming from? i mean if you think its the exhaust then go check those bolts and then test drive and if its gone well then you figured it out
Old Apr 10, 2009 | 09:01 AM
thee stig's Avatar
sounds like its from farther back in the car
Old Apr 10, 2009 | 09:04 AM
N3VO's Avatar
yeah i would say most likely exhaust take a look and see if everything is fastened good.
Old Apr 10, 2009 | 09:35 AM
Evo1001's Avatar
if you still have the stock exhaust, check the heat shields on the downpipe. Mine started to rattle at about 2.5k rpms, then i removed them - no more rattle, then i got a Megan downpipe
