General question
General question
EVOs 8 or 9s, looking into getting one, with a genral tune/bigger injectors/fmic you guys are getting about 330whp?
I'm still learning so thanks.
hey man you dont need the injectors to get to around 330, basic bolts and cams if you got the cash should put you over your mark with the tune, with the stock ecu you can make bigger injectors work, but is will never run as nice as the stock injectors and unless your going with E85 for your tune i dont see a need for something other then stock. if your near rochester ill gladly talk with in person or if you know emery over at street tuned he is a great place to get advice and get the parts you need
Okay what would you suggest, I have an SRT4 as you can see (via sig) at about 330. Obviously FWD would is a whole different pull, but I'm close enough to Rochester, and actually maybe moving there soon :X
--What are "mods" needed for I'd say 400whp ?
