Two guys, two mods, and a tune... in the 11's
#512
New Hoosiers are once again proving consistent. The MPH's are the highest we've seen on this track (ORP) and the 60's were 1.71, 1.72 and 1.71. We never got the tires to spin due to a well prepped track for the Alcohol dragsters. I think if we had been able to play with the tires a little more, we would have dropped the 60's by getting some tire spin. Too much bite! who would have thunk. Jim only had a small air tank with him, so we couldn't air the tires to 30 like we would have liked. Now, at least we're off to a new mod or two.
#513
#515
#519
Indy's at 93% duty cycle on his stock injectors, so we know that adding more power will probably necessitate changing them out. A simple turbo change to one of the new FP-Green's would put the car at the goal of 11.50, total added expense for that would be about $2000. Adding a full exhaust, injectors, O2 housing would probably only get us to the 11.60-11.7 range, realistically and would cost around 1500. A mix/match of maximizing the stock exhaust with various modifications (100 cell cat, O2 housing, improve other restrictions in the exhaust) would probably net a high 11.7 and cost maybe 400-500 (guessing here). Add an ignition system. A Nitrous Pro-Flo System would allow variable power levels and maybe not necessitate changing the exhaust. We're considering that as an option with less expense per horsepower. We only need 50-75 horsepower to get to our goal. Now that we've proven that 11's are possible with the current setup, Jim will have to make the decision as to which way to get to the next level. Incrementally again, or the single jump.
Added: By the way, the nitrous method would not need the added expense of injectors, so that would be a savings over any other method.
#525
n2o is always fun with boost, i did a mustang that made 720 something on 18psi.......so we added a 75shot and made 976.......car ran 8.30's consistently until we threw a 94 on it and made it a race car
