View Poll Results: How often do you change your oil?
3000 miles
87
44.85%
2500 miles
29
14.95%
2000 miles
18
9.28%
1500 miles
17
8.76%
1000 miles
43
22.16%
Voters: 194. You may not vote on this poll
How many miles before the first Oil change.
Old Jun 24, 2004, 02:27 PM
  #76
Guack007's Avatar
2500 for the first and 3k after that. I put 4.5quarts and will add the remaining 1/2 of a quart over time since turbos burn oil. Im still very undecided as to what plan to follow with the tanny and diff oils. Any suggestions?
Old Jun 25, 2004, 07:06 PM
  #77
03venom's Avatar
500 for the first. every 2500 miles after that.
Tranny/diff - I plan on using redline synthetic at 15,000 miles.
Old Jun 25, 2004, 07:11 PM
  #78
raliart's Avatar
i did mine at 870 first on oil, and it was dirty, also did a top speed run after and it burned a little oil, added oil and it has stoped burning, i think the top speed run set the rings. i am strongly considering changing the trans fluid tonight or tommorow just cause you know,
Old Jul 23, 2004, 04:43 PM
  #79
exhaust_note's Avatar
3400 the first... every 4000 after...
Old Jul 23, 2004, 04:45 PM
  #80
BMan's Avatar
I took mine to the dealer at 3K and asked for a change. The service manager told me that Mitsu recomended NOT to change it until 5K. I asked if they had a special break-in oil and he said yes. I didn't have it tested or anything but, I would think he would be all for the $$ if it wasn't a big deal.
BMan
Old Jul 23, 2004, 04:54 PM
  #81
94TurboGT's Avatar
BMan
i hope not i changed mine at 300 miles...
Old Jul 23, 2004, 04:57 PM
  #82
marksae's Avatar
This is the first time I ever heard of "break-in" oil.
Old Jul 25, 2004, 01:17 AM
  #83
Evokid04's Avatar
yea some cars can go 5000 for a oil change but i try to change under 3000 each time
Old Jul 30, 2004, 04:10 AM
  #84
00R101's Avatar
All you so called experts have not included one mention of oil analysis. If you really want to know when to change your oil, here's what you do. Drain a little and send it and a new quart of Mobil 1 10/30 to a lab. The cost is reasonable. They will report all the significant differences between the two samples and can tell you when to change. This approach is based on fact and chemistry, not guess work. There is nothing more foolish than basing your decision on what everyone else is doing. A poll of when others who don't know sqat have changed their oil; what are you people; sheep?
Old Aug 1, 2004, 11:27 AM
  #85
zmeli's Avatar
I changed the oil at 200 miles and there was lots of metal in it. Then I changed again in 800 miles same crap. then after 1125 i sent oil off to Blackstone labs for UOA and there were no wear metals just high Silicon from sealers, normal for new engine.
Warning the mobil 1 10w-30 that was samplied at 1125 miles had thinned down to a 20wt. I would not even think of leaving the factory (break-in) oil in the car for 3000-5000 miles. And if you plan on using Mobil 1 I would not leave it in past 2000miles. I am chosing to use something better YES better. Look a MB approved oils look for ACEA A3 oils that are tested to stay in grade at high speed long drain intervals. but remember 3500miles should be considered a long drain in the EVO. Just have your oil of choice (full synthetic) tested and no more guess work. go to bobistheoilguy.com and do a lancer evolution search to see my results.
hope this helps.
Old Aug 1, 2004, 01:00 PM
  #86
Quick's Avatar
yup, very honest guy and probably the best oil tech around! (around the US at least)
not just on oil either, on other fluids/ additives as well..
Old Aug 1, 2004, 01:07 PM
  #87
TampaTurbo's Avatar
I also changed my oil after the 1st 1000k. People thoughyt I was crazy but its better to breakin a new motor than risk having problems with it later. After that, I would just do it every 3k miles. Unless you are doing alot of racing then I would change it earlier as a safety precaution.
Old Sep 5, 2004, 08:07 AM
  #88
g6civcx's Avatar
Very valid point. This poster hit it right on.
The problem is that oil traps a lot of impurity in the engine: dirt, metal shaving, combustion byproducts, etc.
You can have brand new oil, go racing for 2 hours, and come back with terrible oil. That's why I recommend changing oil before and after every race.
It is best to change oil every day. That way, you know you have a fresh oil supply every time you drive. But you see the problem with that.
Or you could change your oil at 10,000 miles/12 months. Roll the dice and take your chances.
So ultimately it's really guess work. Nobody really knows what is ideal. But a lot of things come into play, like how you drive your car, what you can afford, how much work you're willing to tolerate.
As a service technician (and I know not all technicians are created equal), my recommendation has always been 3-months, 3000 miles, whichever comes first. I also recommend using the highest rated (SJ or SL-rated) oil you can afford in the factory-recommended viscosity.
Changing oil is like cheap insurance for your motor. Plus analysing the used oil will help you diagnose a lot of engine problems, like having coolant in the oil, unusually dirty oil, metal shavings, etc.
Old Sep 7, 2004, 08:35 PM
  #89
Ludikraut's Avatar
I did my first oil change at 2000 miles, done the rest in 3000 to 4000 mile intervals since ....
l8r)
Old Sep 8, 2004, 04:06 AM
  #90
Derek888's Avatar
Due to the humidity, weather and traffic in Taiwan, my Evo 8 owners manual says the first oil change is done at 600 miles and every 3000 after. But I do think this only applies to this country.
TheBoz
30
Jun 13, 2015 02:47 PM
ak47po
Nov 27, 2012 06:33 PM
CarPhoto.net
Driving Techniques
122
Aug 12, 2011 12:15 PM
CarPhoto.net
Driving Techniques
19
Mar 17, 2004 07:34 PM
Quick Reply: How many miles before the first Oil change.
