View Poll Results: How often do you change your oil?
3000 miles
87
44.85%
2500 miles
29
14.95%
2000 miles
18
9.28%
1500 miles
17
8.76%
1000 miles
43
22.16%
Voters: 194. You may not vote on this poll
How many miles before the first Oil change.
Old Oct 1, 2003, 12:30 PM
Chris from CA's Avatar
Question How many miles before you change your EVO's Oil. What brand do you use?
I would like to know how often do you change your oil. What brand you used. Also how many miles before your first Oil change. I am at 1600 miles and would like to know when is a good time to change the Oil. I am not trying about getting the most oil for my money. If changing the oil early helps thats fine with me.
btw theres a picture of my EVO at my webpage http://www.CarPhoto.net
If anyone else would like to post there car with a profile including drive, and car stats email me at webmaster@CarPhoto.net
Old Oct 1, 2003, 12:37 PM
EVO_RPM's Avatar
I changed mine at 1500 miles after break in just in case the were any metal particles floating around.
Old Oct 1, 2003, 12:39 PM
revhappy's Avatar
1,100 for me. I wanted to do it at 1,000 miles, but I had some really good roads I had to drive on!!
Old Oct 1, 2003, 12:43 PM
Thanks for your imput! Any ideas on what brand. Is there anything better than mobil 1 ?
Old Oct 1, 2003, 12:47 PM
webguy330i's Avatar
I changed mine @ 700 miles, then again at 2500 miles. I will be doing 2500 mile intervals from now on. M1 10W30 full syn is what I used, but will be switching to 5W30 for the winter months here at 5000 miles (about a 1.5 months or so).
jotan82's Avatar
i changed at 2k, i have stuck with mobil 1
Old Oct 1, 2003, 01:57 PM
SinCityEvo's Avatar
1000 only because I installed the sports meter which includes an oil temp guage which requires draining the oil to replace the drain plug with the sensor. But my oil was black at 1000. I'm at 1500 now and the oil seems much cleaner on the dipstick. BTW, i used Mobil 1 as recommended. Do it yourself and save money and a trip to the dealer. Walmart sells 5 quart containers of Mobil 1 for like $19.
Old Oct 1, 2003, 02:43 PM
Thoe99's Avatar
I changed mine at 600 miles, right after breakin, cuz it was overfilled from factory, so I drained some out, and on the way out it was so hot, that I just let the whole thing drain, hehe.
Old Oct 1, 2003, 02:45 PM
In Timeout
leaveit2bevo1's Avatar
ouch im at 4300 and its going in on friday for an oil change
Old Oct 1, 2003, 02:51 PM
EVO_RPM's Avatar
anyone know if they make magnetic drain plugs for the evo like the Spoon Sports ones for the Honda & Acura?
Old Oct 1, 2003, 03:17 PM
zTargeTz's Avatar
I changed my oil at 80 miles
then again at 1800 miles (and tranny fluid too)
I sujest changing out your tranny fluid to GM Syncromesh @ 1500 miles or so, and clean off your magnetic plug ( it will need it TRUST me)
my tranny fluid had a copery sheen to it (syncro's breaking in) and a metal chunk or two (doh, dont grind those gears!)
at 80 miles i switched to pure petro based oil to break in my seals and then at 1800 i switched to moble1 synth
I sujest changing your oil before the 1st 100 miles is over, and your trany fluid before the 1st 2000
maybe one more oil change before 2k (with the tranny fluild) then get into the normal 3k oil changes
Old Oct 1, 2003, 03:24 PM
Would changing the tranny fuild explain that funny metal noise when I decellerate and shift into neutral?
Old Oct 1, 2003, 03:31 PM
zTargeTz's Avatar
the decel noise is somewhat common, if it concerns you have the dealership look at it (if its extream)
changing your tranny fluid shouldnt change that too much though i do think that it shifts a lil smother with gm syncromesh (prolly just in my head tho)
Old Oct 1, 2003, 03:39 PM
what is extreme
Old Oct 1, 2003, 03:50 PM
webguy330i's Avatar
I did the drivetrain change (minus the rear diff) with Redline MT-90 and Redline 75W90. That tranny plug was COVERED in metal bits, good lord. Even the center diff had some bits on it, not nearly as much though (more like metal sludge).
Definitely recommend a tranny fluid change, I am going to do one more this weekend, then 7500 mile intervals (every 3 oil changes) thereafter.
Myoilshop.com sells it for mad cheap, use the dealer code to get 10% off (google for the dealer code, can't recall offhand).
Quick Reply: How many miles before the first Oil change.
