Dash lights go off when headlights are on
You try fiddling with the ignition switch? This is a wild guess, but since the dash lights come on regardless of whether the lights are on or off when the ignition is turned on..... Well you gotta start somewhere.
Sounds like a relay issue or maybe even a harness plug has come undone. I ran into this problem a while back with my RX7 and found a small plug under the kick panel had worked itself loose by about 1/16th of an inch. Plugged it back in and didn't have the problem again...thanks to mr. ziptie.
