Will a turbo timer damage a Wideband?
I recently installed a LC-1 in my car and read that if it is not powered and the engine is running it could damage the sensor.
My turbo timer keeps my car running, but the LC-1 loses power when the key is removed.
I was wondering if idling without power will ruin the sensor and should I rewire it to the ignition instead of the cigarette lighter?
If there is exhaust gasses flowing I want mine on. I have mine wired so when my timer is on and the key is out it will keep the unit powered up. Works when I remote start in the mornings as well.
Hmm... good question!
Well, I think all wideband O2 sensors are 'heated', which is one reason they require power. It's possible that one purpose of keeping it heated is to burn off any stuff that builds up on it, like a spark plug.
If that's the case, then I could see the sensor getting contaiminated. Thought it might just get cleaned off next time it gets power.
I'm just guessing, call up Innovate or someone
Until then I will move the power to the ignition circuit.
I'd venture to say that start up is when you would want to be sure you have power so that the sensor heats up fast before the exhaust has a chance to damage it. Once the engine is running, it isn't like the exhaust is going to "cool down" or anything. I'm sure the heating element gets overran by the EGT before too long, but it's needed for that initial start up to keep from damaging the sensor. However, I don't see why you would wire it to anything other than ignition power in the first place. It's not like you'd be checking your AFR when sitting in a parking lot with the key in the accessory position.
OEM oxygen sensors are required to heat up within so many seconds of engine start for emissions and crap. The requirements get more and more strict every year. 2000 was like 1 minute, then it was within 30 seconds...Whatever.
FS[MidWest]: OH: Innovate LC-1 Wideband & Apexi Turbo Timer
Moonman-GSR
Jul 14, 2016 06:08 AM
2MucHP
Jun 21, 2007 08:02 AM
