Broken seat side
Old Jul 3, 2009, 09:35 AM
Alacris's Avatar
Broken seat side
Weird problem, that I'm hoping there's a cheap solution for:
Getting to my driver's side yesterday, I felt a pop from the right side back bolster. It was very loose, like something had snapped.
Today, I undid the fabric clamps and lifted the seat cover up and saw that the back plastic shell had broken. It ties to the metal frame via two plastic flaps and screws. When I got in yesterday I broke one and almost the other. The top one broke as I was trying to get it off gently (it was already in bad shape).
So my question is: is there a part number for just the plastic back shell of the Recaro seats? Mitsubishi wants $1300 for the whole seat assembly. I'll jerry rig something before paying that.
All help appreciated!
AC
Old Jul 3, 2009, 09:39 AM
ak47po's Avatar
Never heard of this happening before.
Old Jul 3, 2009, 09:43 AM
Alacris's Avatar
Yeah, I was surprised too. I could probably attach an angle bracket and bolt it directly to the frame, but if a replacement part is only $100 that would be easier. I am NOT buying a new seat
Old Jul 3, 2009, 09:45 AM
Jim in Tucson's Avatar
Yep, same thing happened to my seat. I'm just trying to be gentle with it and hoping it does not get worse.
Old Jul 3, 2009, 12:41 PM
Alacris's Avatar
Well, I disassembled the seat (easier than one would think), got the backshell off, and saw the two broken tabs.
I JB Welded one back one with multiple coats. For the lower one, I fashioned a bracket out of some old scrap metal. I bolted it in place with some JB weld for good measure. I drilled a corresponding hole. I had to modify a secondary plastic piece to fit around my bracket.
I reassembled the seat and so far so good. I'll probably baby it from now on, but at least it doesn't pop in and out all the time.
Oh, I had no luck finding a parts dealer that had just the backshell. Oh well. If it happens again, I'll look more thoroughly.
Old Aug 6, 2009, 07:10 PM
ashills's Avatar
I bought my car used and this same piece was broken. I fixed it but it ended up breaking again. I guess I will have to beef up my fix this time.
Old Aug 6, 2009, 09:08 PM
Appauldd's Avatar
I repaired the exact same problem on an VIII seat. Took a while to get it apart but pretty easy to fix.
The tabs are flaps of plastic and are quite fragile. I drilled holes in the tabs and the place where it used to mount. I fabricated some thin aluminum tabs and drilled the same holes. Then I, get this, zip tied the aluminum tabs on the plastic tabs and into the seat. Worked like a champ. Seat is like new now.
Old Aug 6, 2009, 09:28 PM
xRoguex's Avatar
Do the leather seats suffer the same fate as the cloth?
Old Aug 6, 2009, 10:32 PM
Hioffcr's Avatar
Location: Killeen, Tx via Fayetteville, NC via Worthington, OH
Have the same issue with my seat. Looks like I got some work to do tomorrow.
Old Aug 6, 2009, 10:44 PM
ApexSafety93's Avatar
duct tape is always a good assistant
Old Aug 7, 2009, 07:34 AM
SmurfZilla's Avatar
man I would just use that as an excuse to get some other seats, Sparco's or Brides
Old Sep 23, 2009, 08:35 PM
GaBe511's Avatar
How did you disassemble the seat?
Old Sep 23, 2009, 08:36 PM
ianm12's Avatar
Customize that shiet!
Old Sep 23, 2009, 08:43 PM
Evoardo IX's Avatar
http://www.capitalseating.co.uk/prod...&appid=&rid=61
That's a UK based website that sells the plastic back, I know there is a US based vendor, but can't remember the name/site
Good luck.
ianm12's Avatar
Good find!
Quick Reply: Broken seat side
