Dealer raped me!
Dealer raped me!
So I took my car to the dealer, they robbed me basically $200 because first hr diagnose they said the piece of **** tech needs additional time to trace the problem for all these codes. Then to find out my warranty doesn't even cover the problems that I am having with my car. The codes were P0134, 138, 234, 243.... they tried to add 2 more fake codes in there... 130 and 141.. I looked at this site http://roadraceengineering.com/evox/...l-dtccodes.htm those codes didn't even appear on there. First time they told me I was missing the BCS and now they are telling me what I'm really missing is the wastegate solenoid. Can somebody tell me where the wastegate solenoid is.. so I can do this myself, those moron dealer are just trying to get money. I also need to get both O2 sensor front and rear... apparently the one that goes to the exhaust was hacked up, at least that's what they said. I want to clear this stupid check engine light and remove the current MBC so I can start doing my own modifications.
You hardley got raped. I got a car transfer case blew up after the 150 mile highway drive home and they didnt honor their 30day FULL warranty.
The codes you have are easy fixes. Take it to a diff dealer tho and get your own code reader for 80 bux. save you money xxxx times over
Didn't honor the 30 day full warranty? Repeat after me : A-T-T-O-R-N-E-Y. Pay the atttorney to draft a letter and serve it to the GM of the dealership and the dealer's owner, with a copy sent to the local news station's "Scam Busters" (every station has something like that). They'll fix it.
If you want "real" help, go to Advanced Auto or any other parts store and get your codes scanned then write them down. Show us your codes with the description it displays and we might be able to give you some advice on how to fix them.
So far:
P0134 - 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0138 - O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor2)
P0234 - Overboosting
P0243 "The PCM has determined that a malfunction exists in the electrical circuit for wastegate solenoid 'A'"
P0130 - 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
See if you're throwing more codes.
So far:
So far:
So far:
yea I might not have gotten ripped off as badly as the guy above with the transmission =\ but either way they only did something that I already knew. do any of you know the part numbers for the parts that I would need to go and fix this issue? thanks
They said since the car still FREAKING ROLLS its not considered broken and didn't qualify as damage under warranty!!!
I called numerous times and spoke to everyone at the dealership about it and all said the same thing. I said the car makes grinding noises and doesn't work right! But they didnt care. Also I bought a 1400$ extended 1 yr warranty for the car that the said 100% covers the car how I bought it. Since my car got ***ed up on the drive home I had it at mitsu like the day after and my boy Mike said "hahah, this warranty wont cover ****!"
I called back that freaking day to cancel the warranty and they woudlnt give me my money back for the warranty. ****, I STILL DONT HAVE THE MONEY!!!!! from the warranty I cancalled the DAY AFTER I BOUGHT THE CAR!
Damn, this is getting me so fired up, I need to take a break.
I did get the car for 12k otd tho.
get a new front o2 sensor, rear o2 sensor, and boost control solenoid. the boost control solenoid is under your air filter. take off your air filter and it should be bolted down to the frame if you still have one, if not, buy one and plug it in and those wastegate codes are gone. once you get both o2 sensors, those codes will be gone. there you go. no need to go to a dealership to figure out what's wrong. the code reader basically tells you what's wrong, and then come on evom to find out how to fix it.
ahah yea..... I knew the codes, but I just wasn't sure if it was one thing causing all those or not. I hear the front o2 sensor go for like $250+, as for the stock BCS..... a guy on here recommended me to get a resistor for it. has anybody ever done this before? a resistor for the BSC plug.. so I don't have to get one since I'm not going to be using it anyway.
Wow, could have all been resolved if you asked to talk to the manager. That always changes their views on things. You probably would walked out of there with some more money in your pocket and your car fixed.
