Power steering removal questions...safe???
I am in need of a custom radiator w/shroud and dont have the space, so a few questions...
1) AMS sells the power steering delete kit... the car is built for track, BUT once in a while on a sunday I like to take a long 3-4 hour drive....
Is it safe to drive without power steering on the highway???
2) If I keep the power steering, Is there an alternative reroute of the lines, i need that whole front space for radiator space and those line are in the way
Car has 2.3 sroked motor and GT35 topmount kit...A/C just removed this weekend.
Thanks
Thanks
Power steering isn't required but recommended for daily driving or just driving in the street in general. If you have enough strength to turn the wheel while the car is off, then no, power steering isn't required for you. But hey, once you start moving the car, it's easy to turn the wheel. Just give it a little gas if you're doing a t-turn or something.
just do it!
i wanna do the same thing, everyone said NO.
I guess no one drove without power steering here?? you can feel the road so much better without power steering, be careful when hitting potholes or it could pull the steering wheel.
if your not DD do it, if your DD and don't mind do it.
top mount + 35R + no power steering = hard core old school style
let me know how the install went, also do a how-to with pics.
GL
GL
Generally there's a difference in steering geometry/alignment between a car that comes from the factory with or without PS.
PS might have more caster and quicker ratio VS manual less caster slower ratio
before a PS eliminator kit purchase maybe just take the PS belt off and see how it feels. Don't know how the kit does it though you may be pushing fluid if the pump isn't running, which would make for higher effort.
