This doesn't sound good....
i know this doesn't sound good but i need to figure out what could have went wrong...just yesterday my car started to have cranking problems...its low voltage and im running mini battery so not the first time and i jump start it...so today i went out to start my car after work and its dead again..so you know what the heck so i jump started it again...then check engine light came on...when i got home and popped my hood to put on my trickle charger for the night.. i hear bubbling sound coming from the head..i know this is not good..i looked closely and saw wet spots between the exhaust manifold to the exhaust port on head...so something is leaking out of the head seem like and the hot manifold is burning it away.... i never race drag or track my car..its daily driver and i baby it...i dont want to think its a cracked head...i checked oil for sign of coolant but looks fine so its just leaking out of the 1 and 2 port of the head....any ideas??
oil level is fine and so is coolant level...can't really tell what the wet spot is from...not sure whats coming out of the head thats bubbling...hoping the head isn't cracked or something
btw..the car runs fine
What does it smell like when it burns? Sweet smell is coolant, but i doubt that you'd be leaking coolsnt on the exhaust side, but you never know. Battery problem sounds like you have a draw. Hook up a meter to your battery and pull fuses one at a time till the reading changes. Check that circut. Other than that, for the leak, maybe its oil from the valve cover. Check what fluid it is. Wait till it cools down, and taste it. You'll need a frame of reference, so taste your coolant and oil, then compare with the leak.
Put the regular battery back in, or go to Mazda dealer, and get a miata battery for $50 and call it a day there. U don't need the lightweight battery to go to Church with, ot worth the weight savings if you don't track the car, and look how much trouble that's causing you.
Is there "oil-like" dampness under the sparkplug cover? Is that the area you see it? If so, that's normal, as there are "weep-holes" on the valve cover there. How bout a picture of where you see it?
its right between the exhaust manifold and gasket... i dont really smell anything and doesn't burn like burnt coolant either...never noticed it til now...
and i know..i shouldve kept my stock battery..was building up the car for track in future but been busy working and working and working...
Is the car stock? Have ant new parts been put on it? Bubbling after you get out of the car after the motor is hot should be ok, its hot water perculating and ok. Does it smell like oil or antifreeze by the "leak?" If you can't see it before it burns off. I say your OK, just get rid of the mini battery with the MAJOR problems.
boost556
29
Sep 1, 2017 01:34 PM
911_Evo
39
May 10, 2010 01:39 PM
