My car wont go above 1500 rpm
Help noob in trouble!!!!
My engine will not go above 1500rpm. It will when it's in neutral but when I put it in gear (all gears) it gets stuck around 1500- 2000rpm. Is this a vacuum line? I didn't hear a pop and nothing is grinding.
I had these same symptoms when my pipes came off. Definitely check them out. Check the one that flows from the intake manifold first. I didn't do that once, and I spent half an hour taking off the plastic shields underneath the car only to find that all the hoses underneath were intact. I learned my lesson on that one in terms of hoses popping off.
