hard to put in gear, mainly reverse
Old Aug 4, 2009 | 02:26 PM
Berts24's Avatar
Mine was doing the EXACT same thing when my clutch was going!! It was so bad I would struggle for minutes to get it into reverse!!! I mean are your rpms jumping when you get on the gas????
Old Aug 4, 2009 | 02:38 PM
worksevo89's Avatar
Registered User
What do you mean by the rpm were jumping as i got on the gas?
Old Aug 4, 2009 | 03:53 PM
Xearo's Avatar
clutch slippage. Like spining your tires in an integra or something in the rain. U go to take off but your rpms go high because your wheels are spinning. Clutch slippage feels similar. When u let the clutch out, your rpms will go higher than it seems like your car is moving because its slipping. kind of like holding the clutch halfway inand giving it gas. Your rpms go up but u dont go as fast as you would expect.
Old Aug 4, 2009 | 03:56 PM
EvoJoeIX's Avatar
adjust the clutch and switch to amsoil
Old Aug 4, 2009 | 04:00 PM
worksevo89's Avatar
Registered User
i dont have clutch slippage
Old Aug 5, 2009 | 09:04 AM
Xearo's Avatar
my clutch is stock and doesnt slip.. yet.. i only launch it once every couple months =)
Old Aug 5, 2009 | 09:43 AM
worksevo89's Avatar
Registered User
Well i bought some Amsoil so we'll see how that goes. Then ill try adjusting, and if that doesnt work ill try checking the TOB. Ill be sure to update you guys
Old Aug 5, 2009 | 12:12 PM
SeeCoryRun's Avatar
Subscribed,
Mines a lil cluncky going through gears first thing in the morning when cold.
Im gunna check that Adjustment thread
Old Aug 5, 2009 | 12:33 PM
gsrboi80's Avatar
Adjust the clutch
Old Aug 5, 2009 | 12:45 PM
kmartizdatruth's Avatar
try adjusting your clutch pedal....same thing happened to me but i adjusted the pedal and works fine now
Old Aug 5, 2009 | 09:16 PM
NsinEvo8's Avatar
hmm, let us know results after fluid.. i would adjust,,, then change fluid,,, if you have too.. but you nver know. gl
Old Aug 6, 2009 | 10:20 AM
worksevo89's Avatar
Registered User
Ill be sure to update as i go. Oil is in the mail. Im going to do them one by one so i can pin point which one it was. Thanks for the help guys.
Old Aug 19, 2009 | 08:40 AM
worksevo89's Avatar
Registered User
Ok guys, I finally put the new fluid in last night. Car drives some much better by the way. I highly recommend Amsoil!
Unfortunately, the car is not completely better. Its still a little rough going into reverse and first. It's definitly a lot better then it was but it not fully cured. Im going to try adjusting the clutch pedal tonight. Hope this one works.
Old Aug 19, 2009 | 10:24 AM
CannabisEvo's Avatar
My reverse is also hard to engage, what I always do is to let off the clutch and put it back in.
Old Aug 19, 2009 | 10:47 AM
1d10t's Avatar
This happened at an autox event after a loss of traction event?
This could put your pedal out of adjustment...how? If it were a gradual change maybe, but not the way you described.
Better check the TOB and clutch assy.
