I'm confused!
I'm confused!
I just purchased a HID conversion kit for my 06 evo 9 GSR. (I did not have HID's on it before.) I am confused because I thought it was a simple 15 min process, but I cant even remove my stock light bulb. Here's my question how do you remove it?! Do I have to remove the bumper and fenders or what?
Your help is greatly appreciated
15 min job if you have a diff car bro. You will have to remove the bumper and take the light out to remove the bulb out and to mount the ballast to the location where the OEM ballast would have been mount. Also, after you install, make sure the light turns on or you'll have to remove the bumper off again. If the light doe not turn on, remove the connector and switch it around. Just have another person there to help you remove the bumper. I did remove and install it myself because I done it a few times already. There is a HOW-TO on removing the bumper in here. Just check it out.
