wft.. someone help please.
Old Aug 29, 2009, 01:07 PM
toverton30's Avatar
could it be bad compression?
Old Aug 29, 2009, 01:22 PM
toverton30's Avatar
update... my oil has a vas smell.. so could it be leaking injectors
Old Aug 29, 2009, 01:30 PM
Kracka's Avatar
Go back to school and learn how to spell. After that, these could be your issues:
1. Spark plugs
2. Spark plug wires and boots
3. Boost leak
4. Dirty MAF
5. Bad tune
Old Aug 29, 2009, 02:45 PM
toverton30's Avatar
im on my fn phone..but thanks for the input
Old Aug 29, 2009, 05:43 PM
toverton30's Avatar
bump........
Old Aug 29, 2009, 06:06 PM
toverton30's Avatar
could it be my fuel pump. it is stock and i just ht 90k.
Old Aug 29, 2009, 06:10 PM
TommiM's Avatar
I would try to diagnose stuff first before just throwing parts at it. First I would make sure nothing obvious is the cause, dv installed incorrectly, hose clamp loose, hose clamp over torqued causing a hose to be out of round (boost leak), loose or damaged vacuum lines. Second, do a boost leak test. Thirdly, check condition of your spark plugs, coils and connections. Remove your intake and inspect your MAF. If its oily, that may be the cause as well.
Old Aug 29, 2009, 07:10 PM
toverton30's Avatar
thanks for that but i have check and check all clamps ..dv.. everything u said.. and im trying to find out how to do a boost leak test... but this search sucks. Thank all of you for your say.
Old Aug 29, 2009, 07:36 PM
Berts24's Avatar
here you go
https://www.evolutionm.net/forums/ev...er-5-02-a.html
Old Aug 29, 2009, 08:26 PM
toverton30's Avatar
thanks man but i found it...thanks anyway. i used google
Old Aug 31, 2009, 06:12 PM
toverton30's Avatar
did a boost leak test today.... there was a leak by the licp.... but by the throttle body.. it was loud hissing...got some mil spec seals.... but its still bucking. i also did a compression test.. 175 for all.
Old Sep 1, 2009, 07:27 AM
aschold's Avatar
No, I doubt it. Make a boost leak tester, I think you have massive boost leaks.
edit: Sorry, I didn't read page 2. It could be your SAFC. My car used to kind of buck a bit under load with an SAFC, so I took that piece of **** off and it runs great.
Old Sep 1, 2009, 08:17 AM
KevinD's Avatar
you have all those mods and a stock 8 fuel pump? has this car ever been tuned? what are your plugs gapped to?
Old Sep 1, 2009, 11:38 AM
njboy's Avatar
+1. I was thinking the same thing. Perhaps a fuel pressure test is in order after the simple things are tested.
Old Sep 1, 2009, 04:18 PM
toverton30's Avatar
ill get on that asap..i think i found the problem....ill get back with yall.
Quick Reply: wft.. someone help please.
