how to disassamble a evo ix wing
Old Sep 12, 2009, 04:59 AM
Dragracer187's Avatar
Does anybody know how to disassemble a evo ix wing, previous owner broke one of the mounting points, I want to fix it.
Old Sep 12, 2009, 06:01 AM
MEVOLV3's Avatar
If same as E8:
*Remove the 4 bolts from the underside of the trunk-lid and the double-sided tape under the feet of the spoiler mounts using floss or mono fishing leader (2 bolts are in sight, the other 2 might be under the rubber stoppers; just spin CC to remove these spacers) Omit if spoiler isn't attached to deck-lid...
1) Remove 4 allen bolts holding the trapezoid-shaped cover on both base peices, revealing 2 more allen bolts that mount the base to the connecting bracket.
2) Remove 2 bolts on both sides of the mounting bracket as mentioned in step 1, this reveals 2 more allen bolts that connect the mounting bracket to the vertical peice of the wing.
3) Remove the bolts that connect the mounting bracket to the vertical peice of the wing mentioned in step 2
DONE
Old Sep 12, 2009, 07:50 AM
I cant see the 4 allen bolts in step 1??? Can I pop the covers from the bases??? Or are they glued?
Old Sep 12, 2009, 10:11 AM
pls1968's Avatar
You can pop them out. They are glued pretty tight so becareful. The inner CF part is one piece. The wings themselves you can remove. I bought a white wing last year and removed the sides and replaced it with red sides.
Old Sep 12, 2009, 11:22 AM
bigben's Avatar
I'm glad someone else besides me was able to take apart the oem 8 wing. I just about got into an internet argument because someone who claimed to refinish the 8 wings swore up and down that the wing could not be taken apart. So I took mine apart "again" and emailed them the pics.
Old Sep 13, 2009, 07:09 AM
MEVOLV3's Avatar
My apologies...my old wing didn't have thoses allen head caps?
Old Sep 16, 2009, 10:59 AM
I managed to get the side off, thanks for the tips. You just have to pull steadily, and it will come off.
Old Oct 5, 2009, 04:37 PM
evil03's Avatar
any pics?? i am trying to refinish a wing too
Old Oct 5, 2009, 05:52 PM
pwrofturbo's Avatar
Old Oct 5, 2009, 06:36 PM
evo9onmymind's Avatar
the glue is stuck quite strong (at least on mine). dont be afraid pull hard on them.
Old Oct 5, 2009, 06:56 PM
sti killr's Avatar
sorry this is off topic a little...
bigben, can you send me the pics on how to take the sides off? i got most of my wing sanded except for the edge near the plastic. i was under the impression that you couldn't take them off because they were rivited.
Last edited by sti killr; Oct 5, 2009 at 06:57 PM. Reason: sorry for being off topic
Old Oct 5, 2009, 06:58 PM
Mr.Roarke's Avatar
Originally Posted by pwrofturbo
i lold.
Old Oct 5, 2009, 09:53 PM
Rxracer's Avatar
Im getting ready to refinish mine so i would also be interested in some disassembled pics..
Rob
Old Oct 5, 2009, 09:58 PM
Bobster22388's Avatar
So if you take apart the wing and that center part is a different piece of the wing. Would there be a part number so we could just replace the middle carbon section instead of buying the wing?
Old Oct 6, 2009, 06:52 AM
aanthonyd's Avatar
Nice!!
Quick Reply: how to disassamble a evo ix wing
