Ebay Engine Damper
Ebay Engine Damper
Has anyone used the engine dampers you can buy off Ebay? They have the universal dampers for about $25 and the dampers with the brackets made for the Evo for about $70. A good bit cheaper than the Weapon R application. Any one with some feed back?
Both mounting plates are junk. Get an Ingalls and be done with it, or better yet, get a front motor mount and call it a day.
save your money and get decent motor mounts. the blox front motor mount (along with other similar designs) is a cheap way to reduce the engine movement that actually works.
The best way to go would be to get the ralli-art groupN mounts, but those are more expensive.
