How many HP should my evo 9 be?
Old Sep 20, 2009 | 09:35 PM
Fantastic 9's Avatar
Question How many HP should my evo 9 be?
I dont know how many have aske dthis, but i have got the following parts on my evo 9 and was just wondering after i put it on the Dyno, how much i should be gaining:
- Invidia O2 housing (turbo outlet)
- 3 inch custom DP with mid pipe
- HKS catback
- HKS intake system
- Forge westgate actuator
- Blitz boost controller
- HKS spark plugs
FYI, i made a run on the dyno on 1.4 bar with intake, catback, sparkplugs ONLY and i made 262 HP ?
Tell me guys what do u think and how much i should be doing wih the paarts i installed !!
Appreciate ur reply..
Old Sep 20, 2009 | 09:39 PM
SmurfZilla's Avatar
Well there are too many variables involved ot compare actual numbers. Only thing a dyno is good for is to compare numbers from say stock and when you add a part or tune. Numbers are cool to quote but it depends on atmospheric pressure, seal level, weather, type of dyno and correction factor.
Soooo many variables. I like a lot of others would be hard pressed to tell you if the numbers are seeing are accurate.
Old Sep 20, 2009 | 10:47 PM
AznEvoIX's Avatar
Most of the modifications you posted arent really modifications at all..... more or less really minor ones.
The only things that you listed that "might" give you gains is the O2 Housing and your Catback. But because you have your cat still, your not letting your car breath all the way.
And +1 to what the guy said to the above.
Old Sep 20, 2009 | 10:55 PM
djslik408's Avatar
to add will this be @ 91 octane, 93, or higher?
Old Sep 20, 2009 | 11:06 PM
xspsi4's Avatar
What kind of dyno?
Old Sep 20, 2009 | 11:14 PM
RockmanX's Avatar
i agree nothing really new there to add to HP
Old Sep 20, 2009 | 11:24 PM
whoang40's Avatar
Put the car on the dyno and then tell us later.
Old Sep 20, 2009 | 11:26 PM
chaotichoax's Avatar
get it dyno'd and find out
closed...
cec12789
20
Aug 18, 2019 12:45 PM
6466Animal
Dec 12, 2015 11:25 PM
PsychDr. HN$
26
May 4, 2013 09:31 AM
BlueEvoG
Northwest Region
55
Feb 4, 2010 09:27 PM
striderx88
May 4, 2007 09:06 PM
