trouble getting crank sprocket off.
alright guys so my crank pulley broke off (the bolts broke off into the sprocket.). i bought a new pulley and sprocket and im currently trying to get this one off. YES I took off the crank bolt (im not stupid lol). but it seems to be stuck on there. i have taken it off before but this time i cant seem to get it to come loose.
i've hit with the hammer, used pry bars on it, tryed to pry from behind the crank plante and nothing will work. does anyone have any ideas??????..
thx
- shane
thx
- shane
thx
- shane
thx
- shane
did you not read my message?.. i said the bolts are broken off.. :0/. its very annoying and i dunno wtf to do now.. gonna try tow ork on it more tomrrow so we'll see how it goes.
anyway else?..
anyway else?..
A tap of some size has to fit in there and a couple bolts you should be good to go!
EDIT:
BTW if all else fails grab yourself a high speed grinder since your replacing that pulley anyways and grind out a notch to use with a gear puller. Use the crank bolt to spin the pulley around as you work.
I don't mean those 4 i mean making the others usable you see?
EDIT:
EDIT:
Usually, when a bolt is broken and the remaining threaded stub is still in the hole, since all tension is gone, the broken end is easy to remove. Try using a probe with a sharp pointed end to back the stub out. Once out a thread or two unscrew it with your hand.
My advice is this...... As said above, use some PB Blaster and let it really soakl for a few hours. Take an easy out kit and remove what's left of the screws. You will drill in to them a bit and the easy out bit in reverse will grab on to the screw remnants and take it out. I bought a used EVO block one time. Half of the oil pan head bolts were broken off and even one in the water pump. The easy out pulled out all of them. Sears has a nice little Crafstman set that isn't too much. GL.
anthonypazsd
134
Jan 19, 2024 11:48 PM
fireroasted
20
Mar 27, 2017 08:17 AM
KevOVIII
18
Nov 10, 2005 08:05 AM
