help me figure out why 2 gauges are inop please
hey guys i was just wondering if you have come across this problem or could lead me into the right direction to diagnose it. i have a 05 RS that comes with the factory boost,volt, and oil temp gauges. the boost gauge operates fine but the volt and oil temp are completely inop and none of the gauges light up when turning on the lights. any ideas. thanks in advance!
adam
adam
^ without even taken it apart im gonna assume what the problem is after you having said that. there is an aftermarket radio installed so im sure they tapped in or cut something messing up the gauges. ugh to people who cant do work right! thanks again though man!
when you pull the radio out if they didn't fiddle with the wiring too much you'll find a white patch harness for the oem sports pack gauge set up...all the gauge wiring is tapped right out of that white harness...you shouldn't have too much trouble figuring out what the issue is from there
sounds like a bad ground, I'm going to assume that the boost gauge is mechanical which is why that is the only gauge giving you a reading. The illumination and sensors all need grounds and could most likely share the same grounding point...I don't know much about the mr stock gauges but that's what my money's on!!!
thanks to all the other replies fellas!
