your modding environment
#31
And thanks for the environment kudos.. as we are having a huge Christmas party in the garage this year.. while it is clean and before tables get set up... I'll take some pictures, expecting 46-50 people. =)
#32
my advice for starting a tool collection is to buy the tools as you need them. Though i would start with a set of sockets, open ended wrenches and other basics.
you dont need air tools, though they are nice. A 1/2" breaker bar + pb blaster with undo almost anything.
do get a nice jack stand (i have the tire rack version). ramps are nice as well, if you want to lift all four corners, they will make that easier.
I would post a picture of my garage, but its full of boxes and furniture
#34
Radiant heat is one of the most efficient heat sources (short of geothermal)... This allows for a dead quiet heat source (namely quite a few TONS of concrete) heated to 70+ degrees, to then radiate through the entire garage, remember heat rises, so if the FLOOR is heated, and heat rises, this is a very even heat.. not 'forced air' heat that heats air and not objects, nor a ceiling mounted unit... I have maybe $3500 in the entire setup, and the mechanics are all in the basement, just the thermostat to control it is in the garage.
I had been through plenty of electric heat options.. gas heat options, and torpedo heaters as well.. this setup made the most efficient sense for what we were trying to accomplish. I may do a surface lift in there someday, but not a bolted in style, not at the risk of punturing a pex water line in the concrete. Thanks.
you have a badass garage!
#35
I just went to home depot and bought the husky HD tools or whatever
have all ratcheting style wrenches, all my sockets 3/8 and 1/2 drive, deep sockets etc
i spent under 300$ and pretty much have everything ill need tool wise
Or u can get stuff from lowes, and pick up one of those 15% coupons
got 4 jackstands from harbor freight, and got a heavy duty lowprofile jack with a siqq LED light on it for 100bucks lol
After winter im probably going to buy a standup air compressor and one of the earthquake guns or whatever from harbor freight, i guess they are pretty good quality. After doing my car during the fall with mostly air tools, its so much faster and easier to work with.
As far as taking out a motor, exhaust, suspension stuff goes
#36
100% electric house, yet to have a bill creep over $350 in the winter.
#37
Just an FYI... in our area, the post office "moving packets" have a 10% off lowes coupon... (packets are free just have to go in and ask for one), and Home Depot, Menards, etc all honor those coupons as well..
#38
Where are you finding a jack that lifts more than 23"?
http://www.homedepot.com/Tools-Hardw...atalogId=10053
#39
You can get that but, harbor freight is a good place to go for that kind of stuff. i got the same jack basically with a lifetime warranty incase it ever breaks.. just go in and get a new one
#40
Should have taken some pictures this weekend.. as I de-modded the car, back to stock wheels, winter tires, stock springs, silencer... was a productive weekend, and definitely enjoyed working on a warm floor, and one that can be cleaned up with a wipe (never liked oil soaked/stained concrete look)
#41
My setup so far:
Jack and a couple set of jack stands (necessary)
Work bench with a mounted vice (necessary)
Large Craftsman toolbox
Full set of 3/8 shallow and deep 6 point and 12 point \
Full set of 1/2 shallow and deep 6 point and 12 point Metric and standard
Full set of 1/4 shallow and deep 6 point and 12 point /
Full set of Flat head and Philips screw drivers from stubbies to 14"
1/2" 16" long breaker bar (necessary... trust me)
Several sizes and types of ratchets, 1/4 3/8, and 1/2
Full set of box end wrenches for metric and standard
Several extensions for ratchet/sockets from 3" to 12"
Ratcheting wrenches (sooooo awesome) metric and standard
20ft/lb-150ft/lb torque wrench
10in/lb-200in/lb torque wrench
Metric and standard allen keys
Torx drive
Various sizes of adjustable wrenches
Soldering kit with lots of butt connectors etc....
Dremel with lots of cutting/sanding/buffing/etc...
Drop lights (more than one, necessary)
Kerosene heater
Extendable magnet (NECESSARY)
Hammer and rubber mallet
Ramps
Oil drain pans and a bucket to dump them into (I do 3 or 4 cars at a time when I do our oil changes)
Table mounted band saw
Miter saw
Table mounted router
Electric end grinder
Electric drill
Battery powered drill
I have a ton more, but I can't list it all.... Next up is a big compressor and air tools. I buy mine as I need them as well, and I only buy Craftsman and Snap-on due to their warranties/quality. You'd be amazed at how often you can break something when working on a car, case in point I shattered 2 19mm sockets a few weeks ago trying to take apart the front suspension on my Evo to install some Swift Spec-R's. Free replacements :-D
Torx drive
Kerosene heater
Ramps
Miter saw
Electric drill
#42
Broke two 19mm sockets!?! Wow.. is your car sitting outside or in salt all the time? I just did put stock springs back on mine, (2004 evo w/ 84k miles) and broke them loose with a 1/2" breaker bar, no issues.
#43
Tool box looks familiar lol
I think i bought my tool box first since mine doesn't have the bling bling wheels on it.
This is a pic of my box, my roll cart and my buddies garage where i work on my dsm. I was a tech for 7 years and lost my job for leaving a note on a 1g GSX asking if they ever wanted to sell it to give me a call. Two months later i bought my laser, but lost my job.
#44
The best investment in tools that I have done is for an air compressor and quite a bit of pneumatic tools. Impact wrenches are amazing and make most jobs go that much quicker. I typically buy the tools as I need with the exception of last year where I bought a large list of tools that I wanted. Working on the car is much easier now and the only thing I don't have that I would like is a garage to work in. I would take a non heated garage at this point since I have to do everything in my driveway.
I also bought a majority of my tools and equipment online from an assortment of sites. You can find great deals online and a majority of the tools I purchased were tax free and shipped free.
#45
Online is a good way for things that are expensive, to save tax... as long as the 'free shipping' isnt built into the price, which isn't uncommon. Yeah, I did the driveway work before... parking lot work... and made sure that when we built the house.. I had plenty of room to 'grow' into...
Agreed on the air compressor as well.. I have a 60 gallon, 5 (real) h.p. 2 stage.. puts out over 17cfm @ 90psi.
