oil light flicker while driving.
Hello,
noob here , recently I notice my oil light flicker every here and there while driving at certain speed.
I'm pretty new at this problem so I don't know where is the oil pressure sender and the pressure switch is located on the evo 8 engine bay . I tried to google it , but
come up short .
So can any of you point out the location of the oil pressure sender and the pressure switch on a picture of the engine bay.
thanks......
come up short .
thanks......
I think I found the oil pressure sender, is the oil pressure suppose to go all they
way into the engine?.because their is alot of gap between the sender and the cylinder block.
it locate just above the transfer case, but
is so cramp in there how do I get to it with out dropping the tc,
if the light comes on when you are driving at all its not the weight oil you used. The light comes on when the oil pressure is really really low. I could see the weight of oil changing weather it comes on at idle or not but once you build some rpm and you still see it I would be freaked out.
In you case I would hope for a bad sensor.
THUB
Aug 9, 2012 06:12 AM
