Shifting problem
OP, try the Blox front anti-roll mount. I used to have the same problem but after switching to that, the problem is gone. Also, if you're using a GL-5 fluid, drain it out for a GL-4. I use Royal Purple Syncromax.
Definitely try a stiff front motor mount (the BLOX front engine roll stopper is what I have and recommend) and some underhood and base shifter bushings (I recommend the Speed Source ones since they're self-lubricating brass). I'd also switch your 6-speed back to the OEM DiaQueen fluid or that Castrol stuff Mil.Spec sells.
