whats a stock 9 turbo sell for
You Abosultely CANNOT get a functioning 9 turbo for $100. You can pick up a FP Green for a bit more than the 9 and the Green would hold boost better up at the top of the RPM Range, but the Evo9 turbo is still good none the less. At max spend $475. Let us know how it goes. Gl with your build.
i dont want a fp black. a fp black is not going to get me over 700 whp. im thinking about buying this turbo cause i can get it for like 100. im going to put it on the car till i have enough money saved to build my motor. i may just buy the turbo and post it up for sale on here if i can make some quick cash off it
Hope that helps.
That's correct, if it says its 9.8t, it's probably an 03 or 04 evo 8 turbo. The '05 8 turbos had 10.5 turbine housings like the 9. There's another set of numbers stamped onto the compressor housing, iirc, the 8's were 49378-01590, the 9's were 49378-01580
Hope that helps.
Hope that helps.
Found some IX turbos for sale on here. Some are already sold but just to give you an idea how much they go for.
https://www.evolutionm.net/forums/sa...-ix-turbo.html
https://www.evolutionm.net/forums/sa...rbo-socal.html
https://www.evolutionm.net/forums/sa...2-housing.html
https://www.evolutionm.net/forums/sa...oken-stud.html
EDIT: Added links
EDIT: Added links
ok. for the tenth time. i was only going to get this turbo cause it was cheap. buy the time summer gets here i will have a built motor with at least a 62mm turbo on it. i figured i could make a few more hp with this turbo than the 8. do you get what im trying to say?
Here is a Evo 9 turbo on eBay.
Starting bid is $500, buy it now set at $625.
http://cgi.ebay.com/ebaymotors/mitsu...Q5fAccessories
evo 9 turbo has a 10.5 housing/single flap wastegate/better compressor housing. The evo 9 is a great turbo upgrade for any evo 8. They usually sell here in the market place 400-500 bucks. I wouldn't pay a cent more for one.
Gruppe-s has them for 800 bucks brand new w/an evo 8 install kit with free shipping. That is the best price hands downs that I have seen online.
well if this turbo is to small for you set up why don't you roll with a 8 turbo until u get the motor build and just go to a bigger turbo u want..? why waste the extra cash on a 9 for a few months? when the motor is going to be out anyway? to be built and not driveable? unless i read the whole thread wrong :-D
