Gauge Problem, Would appreciate your input :p
Sooooo this is what my current setup looks like:
Now I just bought the Aquamist HFS-6 Kit. As most of you know it comes with a gauge (i think its 52mm <-- correct me if im wrong).
Now that this gauge in the equation i cannot do this setup. I've been searching like a mad man lately to see what my options are and Im leaning towards the Rexspeed Triple gauge pod:
HERES THE PROBLEM:
The gauges I run are:
- 60mm Defi Boost Gauge
- AEM Wideband
- and now Aquamist flow gauge
1. Do u think that the 52mm ones will fit okay in the 60mm ones? I dont really like the look of the Rexspeed 52mm version.
2. Also the fact that the gauges dont match...will that look stupid you think. I dont think it will.
3. I was thinking of doing the sequence : Defi, AEM, Aquamist , it would flow quite well.
INPUTS, ADVICE.......PLS LEMME KNOW.
HERES THE PROBLEM:
- AEM Wideband
I would just try to trade your 60mm Defi with someone that has a 52. I don't think it's the end of the world as far as size, but the 52 will definitely just fall through the 60mm openings, and the 60 will definitely not fit in a 52 without some filing or cutting.
