Navigation and Auto Climate Control
#31
Well, my comp boot time will be 10seconds roughly, so boot time: not a problem. I believe the direct pressure of placing the servos on the flaps would require more torque. Im using 6 servos for simplicty, and as for not having a/c or fan until it boots up (it will be on your last setting when the cars started.)
-J
-J
#32
Originally posted by CombatCQB
Everything else is electrical and can be replicated by any microcontroller I/O plus maybe a relay.
Bryan
Bryan
#33
Your going to have to use 1/4 scale servos to get the torque you need.. And you definitely don't need servos for anything but the Air mix.. the fan switch is a rotary binary switch.. and the others are momentary or dpst pusbuttons.. you can provide reference signals by using a microcontroller and a debounce circuit.
#34
Aww man. You stole my idea!
Let me know how it goes - I will be doing the same thing.
Right now I am getting the interface programmed right and proper. The servo control is being done via serial and an OOPICII-R servo control board.
Not alot has been done lately on it (friggen cc debt) but work goes on none the less.
Also 1/4 scale servos are not a neccessity - standards are strong enough.
*edit* Damn forgot to mention the coolest feature I plan on implementing. If all goes well I will also have servo control over the 4 vents in the dash. (left/right : up/down : open/close) Can we say occilating vents
#35
I'll be interested on how you fit the servo and linkages.
I have to say that I'm working on this project too. I'm using an Atmel uC plus an IC thermostat that will create a fully automatic climate control system. All the knobs and switches will remain the same unless I replace them with rotary switches. Trying to think how to integrate the 4x20 LCD display. Also plan to add some additional security features if I have extra MIPS to spare.
Bryan
evolutionated
May 15, 2012 06:08 AM
drewblueeye
Oct 19, 2006 05:05 PM
