help please (multiple codes)
my car is throwing a fit... first it was a random misfire code, so i replaced the plugs and that stopped. the next day, it would hardly even idle and threw another SES light. the codes were:
P0340 (twice)
cam position sensor
P0335 (twice)
cam position sensor circuit malfunction
P2228(twice)
Barometric pressure circuit low
P0171
system lean
what connects all of these?or could it be multiple problems? i was thinking maybe the Fuel filter and pump needed to be replaced since it doesn't respond immediately to throttle inputs and the lean code. thanks everyone for any help or ideas.
Josh
P0340 (twice)
cam position sensor
P0335 (twice)
P2228(twice)
P0171
system lean
Josh
no cams. just pulled the MAF to check it and the connector was FULL of water and the pins were all corroded. tried to clean/ dry off the pins and one fell off. FML!! I bet this this is expensive. could this cause the cam sensor codes as well?
blackblaze427
Feb 23, 2009 04:37 PM
BadazzCR
Aug 23, 2008 07:40 AM
