Buying an Evo dealer insists it is an MR but I don't think so
#33
the hood lines up fine with the rest of the body, must not have closed it all the way before the pictures or something. the front doors have some kind of ding protectors so the gaps look smaller. unless I get an amazing deal I will probably just walk away but I'll see what I can talk them down to
#34
didn't see the door line that was talked about. the hood that looks simple enough. The rubber hood rest is set too high. Not sure if covered but not stock headlights. The bumper being off could be from it being removed and put back on. Mine does it now on the right. No front crash beam helped that a little. I would car fax and look for more evidence of mods that might have been removed. Take someone that know these cars.
Oh check to see if the 60K service was done. The timing belt job.
#35
can just tell by this picture right here
http://autobase57-px.rtrk.com/cgi/sh...=-1%26size=640 no Mr 6 speed shifter=no mr
as stated earlier its just an SSL
also no vortex gen.. no mr badge... no bilsteins...
def NOT and MR
GL witht the purchase..
but FYI if a dealer doesnt know if its an MR or not i wouldnt buy a car from there!
def NOT and MR
#36
yup no mr its all good get it checked out compression test and a TEST DRIVE after the brake pads are replace before you even consider this car. with 70k i would not pay more then 15500 for it. mine had 48k when i bought it in PA and i live in LA and it was less then 17.5k
