Throttle sticking!!
Old Jan 28, 2010 | 03:00 PM
RedWing03's Avatar
Throttle sticking!!
Lately I've had this stupid problem with my throttle sticking around the resting area. So it's holding the throttle open and leaving the engine around 2500rpms. It's almost as if the spring is too weak. Any know any possible solutions. This is making the car extremely annoying, specially in the snow. I have to kick the throttle to make it idle back down to where to needs to be.
Old Jan 28, 2010 | 03:09 PM
tweakdsm's Avatar
Take upper pipe off, where throttle body is, and inspect it , maybe its dirty inside, clean it.
Old Jan 28, 2010 | 03:13 PM
itsurismicah's Avatar
Maybe it's a Toyota
Old Jan 28, 2010 | 03:14 PM
kanyonkid's Avatar
WD40 the throttle cable at the throttle body
Old Jan 28, 2010 | 03:16 PM
EVO 4G63's Avatar
Originally Posted by itsurismicah
Maybe it's a Toyota
Haha Ouch!
Old Jan 28, 2010 | 03:21 PM
RedWing03's Avatar
I've cleaned it a few times. And yes, the spring has been lubed. Throttle body was cleaned when I removed the intake.
Old Jan 28, 2010 | 03:26 PM
lucky_evo's Avatar
had the same issue. took the pipe off the throttle body and cleaned the throttle plate.. was really gunked up on the backside of it causing it to not close properly
Old Jan 28, 2010 | 03:30 PM
evolution2186's Avatar
Mine also being an 03 8 has had this same problem. Mine also rev's up 400-500rpms after pushing the clutch in to shift. This are all very common problems. I know many suggest using an aftermarket throttle body.
tweakdsm's Avatar
could be also a tune, or bov leaking (spring not closing)
Old Jan 28, 2010 | 03:50 PM
Pal215's Avatar
Check your throttle cable location. Some people had problems with their throttle cable binding when tucking it away. If its in stock location than it cant be the problem.
Old Jan 28, 2010 | 03:53 PM
RedWing03's Avatar
I've worked with the throttle spring a bit, and when you turn it by hand, it definitely does seem to get a rough around the closed area. If you dun come from like 1/4 throttle and snap it closed, it get stuck. Maybe I will have to take it off and look into cleaning it again. Almost feels like vacuum is holding it open, if that even makes sense.
Old Jan 28, 2010 | 03:54 PM
RedWing03's Avatar
And the cable is in the stock location, I checked that first. Throttle gets stuck even without the cable on.
Old Jan 28, 2010 | 04:06 PM
tchouko's Avatar
I had the same problem dude...feels like the car is possessed...i used some WD40 sprayed the spring on the pedal...and cleaned the throttle body...now it's all good...
Old Jan 28, 2010 | 05:12 PM
chinoxmk22's Avatar
Maybe it's a Toyota
lol
Old Jan 28, 2010 | 07:44 PM
esmjoe's Avatar
Maybe it's a Toyota
+1...Carfax..Haha
Quick Reply: Throttle sticking!!
