Car stutters at WOT in 3rd and 4th gears. Bone-stock
You always want to check gapping. Who knows if the plug has been dropped and bent out of spec...
Ok, If the gap on the spark plug is too big, (pull one out, and check the gap) and your geting on the gas, the BOOST will "Blow out" the spark, and will give you a shudder mis-fire. Remedy, is to lower the gap, and try it again. should fix that. Depending on the mods on the car, you can run cooler plugs, which will make it run better also. Also, If you get a "Cone" intake, the "Oil" on those, sometimes can get onto the tungsten wire in the MAF sensor, and make it run like ***. Just my 2c, because that's all I got. lol
DRAG
538
Apr 10, 2015 02:06 PM
detroit pistins
18
Jan 22, 2014 11:37 AM
hoof hearted
38
May 1, 2013 03:15 PM
