Boost Issue need Ideas
Old Feb 2, 2010, 05:28 PM
paposse71's Avatar
Just installed a ProSport boost gauge for my first mod from what I've been seeing the IX should be seeing 19lbs but Im only seeing 15-16lbs. Im going to do some trouble shooting with another boost gauge. I tapped in right from the FPR. You guys have any ideas? Thanks from a NUB!
Old Feb 2, 2010, 10:35 PM
Andrewkbmx's Avatar
do a boost leak check, and im sure those pro sport gauges are off by a few arent those the autozone brand ones?
Old Feb 2, 2010, 10:38 PM
GEOFF[4G63]'s Avatar
not autozone but they are relatively cheap. when mine is off it stays a hair under 0.
MR_Lance's Avatar
^ +1. Crappy quality of the gauges, or you may have a leak.
Old Feb 2, 2010, 10:47 PM
Matt D.'s Avatar
On my VIII at stock boost it would spike to 18-19 then would always settle around 15-16. Doing a boost leak test never hurt anyone.
Old Feb 3, 2010, 08:55 AM
paposse71's Avatar
I didn't think the gauges were supposed to be that bad seems like a lot of guys are using them. I guess another gauge will tell me what to do next. Thanks!!
Old Feb 3, 2010, 12:11 PM
chaotichoax's Avatar
boost leak test before you get another gauge
Old Feb 3, 2010, 01:31 PM
andrewzaragoza's Avatar
yeah check for boost leaks first. also it seems like your car isn't tuned yet. give cbrd a call they should be able to help you sort out your issues.
Old Feb 3, 2010, 01:59 PM
boosted91t's Avatar
At what point are you seeing the 15-16 psi? Like the other guy said, The boost is gonna taper off
Old Feb 3, 2010, 02:45 PM
oneofakindtrini's Avatar
+1. YOu don't want to go drop $200 on a Defi gauge, when that isn't the problem, if it is tho, Defi Gauges with the Defi Link are the way to go!
Old Feb 3, 2010, 04:22 PM
Svendiesel's Avatar
Ive got prosports mine are all problem free. You can get 3 Prosports for the price of 1 stupid Defi. 3 defi's = might as well go buy cams instead for that kind of money, dont be stupid.
I do a boost leak test every 2 weeks just to be sure theres no leaks anywhere. I carry the tester in my trunk lol
Old Feb 3, 2010, 05:41 PM
geardog75's Avatar
a ton of people use prosport gauges because they are pretty accurate for the price. it could be possible you need to turn your boost up?
Old Feb 3, 2010, 06:42 PM
paposse71's Avatar
Thanks guys....def. not going to buy a new gauge I'm just going to borrow a friends for a quick test. I will try leak test after I try the other gauge, I just wanted make sure I wasn't missing something!! To answer when I'm seeing the 15-16lbs it hits and holds there not seeing any spikes.
Old Feb 3, 2010, 07:40 PM
kpr
kpr's Avatar
Probably the gauge. Is it Electric or Mech.
Old Feb 4, 2010, 04:44 AM
paposse71's Avatar
Mech
