Frost INSIDE the car.
So I'm on Ohio and is COLD. However, I have been getting into my car in the mornings lately and there has been ice on the glass INSIDE the car (usually outside too, but not always) I mean obviously its cold, but it just seams weird to me that the inside is frozen. Is moisture somehow getting into my car? Should I run the AC to get moisture out? Anyone else experience this?
Thanks!
Thanks!
Never saw this in 5 winters in my evo. I'd say there is moisture getting in somewhere. Being you have a MR check the passenger side firewall where the factory gauge wires come through if I'm not mistaken. May be getting it coming from that area.
Silicone it up if that looks to be the case
I recently saw this happen to a guy at work with his Prius. I was always under the assumption that it was due to a leak in the ventilation system that allows air to be exchanged with the outside while the car is off, or something like a leak in a door seal. Leaking heater cores will cause the same thing as that moisture is in the ventilation system, evaporates and goes straight toward the windshield.
i have never had this happen to me.
mitsubishi would probably not find any cause and send you on your way. however, if it was a significant leak they did find then yes, they would warranty it.
it might not be that they are freezing overnight, but that there is moisture already in there and fog on any windows would turn to ice.
maybe try windexing or cleaning your windows and drying them and see if it still happens.
This usually happens in cars when people don't kick off the snow/water from the boots before they get in. I sit in the chair, lave my boot outside the car, then clap my boots outside the car about 5 times so all the crap falls off, then bring the boots inside. Having rubber floormats in winter helps a lot as well, since you can just take out the rubber mat and pour out the water/shake off the snow before you lock up the car for the night.
You can try taking a shop vac to your floor mats and under them to get rid of some of the water. You can also leave your windows a little open during a dry day so the water can evaporate out of the car (yes, it still works on cloudy and below freezing days)
It was a daily occurrence for me when I used to live Canada... I think the conditions have to be just right, the right humidity, enough water and the cold temps outside. I never had it happen here yet in PA as an example.
