what problem could this be
try doing it when the car is moving in neutral. you may very well have a 2 step on your car if it was previously modded, but need more info to really get an idea of whats goin on
That could be somewhat possible, but a longshot for that to be the problem. What mods does the car have? Have you gotten any CEL's?
yes it star normally it sounds good, no i have not changed the spark plugs ,im not sure if it was mod before or tune, what i know is that with out pushing clutch i can start engine.
but when my mechanic plug the computer it says that the maf is low air
1 Post
I had a car in the shop with a similar issue, wouldnt rev past 5000 rpm while driving, but would stopped in neutral. It ended up being crappy gas. I replaced the fuel and it was back to normal. I had noticed a high knock count.
The car was an acura, but just throwing it out there. If you have a CEL you need to repair this issue first.
