Exhaust Silencer
Exhaust Silencer
I've read those several posts showing that using a silencer can reduce HP, in some cases by 10+. I installed my silencer this afternoon thanks to a local law enforcement citation. I did a pull before and after the silencer. Same part of road, temp, etc. Timing, Load, Boost were all identical. I also graphed them via the VDR sheet, and it was indeed spot on with my "base" pull.
Is it safe to assume that in my particular case, if Timing, Load & Boost were identical on both pulls, that nothing has changed? I am mildly tuned (cams, mani, meth, etc) and can't believe what I am seeing.
Am I missing something?
Hmmm I don't know much about the mechanics of HP change but I would say that if you can repeat your results more than once it holds weight in the argument of change and you can better conclude what you think
good luck
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
ive never seen no power loss from adding a silencer if you have a 3" straight exhaust with no resonators or cat. depends whats in your exhaust that could effect that. if your exhaust is restrictive than maybe you wouldnt lose that much power
![](http://i49.tinypic.com/t8lx1x.jpg)
You don't know the half of it. I live in Clermont (small country like place outside Orlando. Nothing better to do than "Fix-It" tickets. Unmarked FHP got gas with me at a gas station. He waits till I pull out of the gas station, then flips his lights on saying my exhaust was illegal. I ask what about it was illegal. Too loud, etc. He says "it just is" and writes me a fix-it ticket.
So I keep the silencer on and $100 later enjoy a very quiet car with what I can tell to be no loss in HP/TQ.
this +1.
its all in your head. jokes...
there is probably a difference. but i cant explain why. air will still be flowing out but less because of the silencer?
i had the greddy tic competition catback. its like a regular tic out there but it doesnt have a resonator. i installed the silencer on not because of cop issues. i kept waking up my poor neighboor everytime i go in/out of our indoor garage. the exhaust resonates through the wall and stuff so yeah.
its a big difference noise-wise before and after. im sure there is a performance difference there somewhere.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
I have an AMS TBE w/ cat, so technically my exhaust is legal in NC. I will be switching over to my FL plates asap, I do run a silencer in my exhuast. Only because my car is really loud, and would wake up my wife when I worked dayshift. Otherwise I didnt notice a difference in power.
