for those running mini batteries
Old Feb 23, 2010 | 03:44 PM
EvoJoeIX's Avatar
how do you like them? ever have any problems?
im looking to buy the ets mini battery kit. i daily drive my car. im just worried about getting stuck in the cold weather or something.
Old Feb 23, 2010 | 03:48 PM
Psquared's Avatar
Do yourself a huge favor. Relocate the stock battery to the trunk and spend the $ on something else. You can relocate the battery to the trunk for less than 100 bucks. All you need is a battery tray. You can use the stock tie down and J bolts, pick up the wiring below with breakers and you're set.
http://www.streettunedmotorsports.co..._reloc_kit.htm
Old Feb 23, 2010 | 04:23 PM
EvoJoeIX's Avatar
does the stm kit come with directions on how to do it?
Old Feb 23, 2010 | 04:26 PM
K1lla Haz3's Avatar
I keep hearing that mini batteries suck in the cold weather....
Old Feb 23, 2010 | 04:33 PM
nothere's Avatar
if you run the car every day I can't see you having any trouble. I can leave my car for about a week before there is a chance it won't start.
got a mini battery in the trunk
bbyevo8u's Avatar
cool... i think im buying it
Old Feb 23, 2010 | 04:34 PM
EvoJoeIX's Avatar
so have i, thats why im leary on getting one.
as my only transportation right now, id be pissed if i got stranded somewhere
Old Feb 23, 2010 | 04:37 PM
chaotichoax's Avatar
I had one for two years
started every time even if I let the car sit for 4-5 days at a time...however it didn't turn over very easily
I ended up putting a full sized battery in the trunk
well worth it in my opinion
Old Feb 23, 2010 | 04:45 PM
EvoJoeIX's Avatar
i just talked with emery from STM. looks like im going battery in the trunk route
Old Feb 23, 2010 | 04:49 PM
ncaruso23's Avatar
Good choice.
Old Feb 23, 2010 | 05:10 PM
ETS Michael's Avatar
Why are you relocating the battery? Why not keep it in the engine bay? You can run a stock route piping kit and the stock battery will stay. The only problem I see is if you relocate the battery to the trunk.. depending on the track.. You may need to install a cut off switch on the outside of your car or they will not let you run. I would double check with your track first. If you do this, make sure you get a removable switch so people don't tamper with your car in the parking lot. Hate that..
Thanks!
Michael
Old Feb 23, 2010 | 05:20 PM
churchja's Avatar
From my own personal experience, mini-battery = bad idea. I've tried the AMS, Odyssey, and now Baker. Lots of headaches and waste of money. Take some good advice, don't do it. For every person that has never had any problems with their mini-battery, there are two others who have had troubles. Don't do it unless you like to gamble on crappy odds.
https://www.evolutionm.net/forums/sa...-bov-more.html
Old Feb 23, 2010 | 05:28 PM
metalsaber's Avatar
Been running a mini battery for 6 months without issue. I've parked the car for the winter and start the car up once a week and it starts up just fine.
Old Feb 23, 2010 | 05:37 PM
Psquared's Avatar
If you can run a power cable for an amplifier, you can relocate the battery to the trunk. It's simple. It's so nice having the battery in the trunk out of the way. If you ever install a meth injection system, the battery is right there to wire up. Being able to run short route IC piping is nice too. PM me if you have any questions about wiring it up.
Old Feb 23, 2010 | 05:46 PM
EvoJoeIX's Avatar
Thanks!
Michael
i was actually talking to you about this today through emails mike.lol
im relocating the battery because im gonna be running your short route ic pipe. i know you guys make the stock battery pipe, but i like the look of the short route. i was gonna go with the mini battery kit, but i just have heard to many bad things about them. especially in cold weather.
Quick Reply: for those running mini batteries
