Setting Gizzmo ms-ibc
Hi Grant
i have a gizzmo ms-ibc and i want to set my boost to around 16 psi. I downloaded the simple setup guide you had on the forum and follow it correctly. I set the duty cycle to 50 and the gain to 12. When i flow it in 3rd gear it peak at 16 -17 psi and From 5500k to redline it falls off back to 11-12 psi. Is there anything i can do to allow the gizzmo boost controller to hold the 16 psi all the way to redline? Your help is greatly appreciated or any or you guyz who use the Gizzmo ms-ibc controller.
Thanks much.
Thanks much.
