Please help with ABS codes, 5 codes
Old Feb 27, 2010, 02:36 PM
HiRevnVIII's Avatar
Hi Guys, drove in snow a couple weeks ago, hit a plows snow remnants and ended up doing a 360, smacked a curb when i came back around with the RR wheel, bounced off that then hit my RF wheel, although going much much slower. Amazingly no wheel damage! Anyways, i replaced the RR speed sensor after checking the tone ring, seeing it was good, no teeth missing, thinking that was surely the issue. well, it didnt fix it. read on here how to pull the ABS codes by grounding pin 1 on the OBD, and it came back with code 11, open circuit in right front wheel speed sensor. also threw codes 21, 22, 23, and 24, short circuit in RF, RR, LF, LR wheel speed sensors. Wondering if its only pulling those codes because there is one bad sensor, and therefore makes all sensors show faulty, or if there is something else seriously wrong.
thanks in advance!
Old Feb 28, 2010, 08:48 AM
HiRevnVIII's Avatar
thing that go BUMP in the night
Old Mar 1, 2010, 05:58 AM
HiRevnVIII's Avatar
Well ive got the codes, trying to figure out if its throwing 5 codes because one wheel speed sensor is bad and it throws off the whole system, or if there is something else wrong.
static_set
15
May 18, 2023 12:51 PM
whitefrs
Jan 28, 2017 09:51 PM
Dangerdave
Jun 4, 2015 06:56 PM
rastaj0ker
Lancer Troubleshooting
Oct 26, 2009 08:13 PM
Atlas
Jan 4, 2009 08:28 PM
Quick Reply: Please help with ABS codes, 5 codes
