Need help finding thread about taking wing apart.
I need some help looking for a thread about taking the evo wing apart.
I know for fact I have seen the thread and the wing was taken completely apart. The sides and the center were separated. I remember reading they were only held together with Velcro. This thread was pretty much a how too. Sadly though my search skills are less than perfect and I am not able to find the thread.
I am looking for this thread as sort of a pointer so that I can get my wing center sanded and cleared.
Any help would be appreciated.
Raistlin
Raistlin
no, the sides are not velcro. lololol. but you can sand and clear the wing with it on the car if your careful enough. or you can just take the wing off the trunk and do it in your garage. theres a thread that shows you how in show and shine i think. i just did mine on the car this past summer. ALOT of hard work and sanding, but it came out pretty good. i used U POL #21 clearcoat and that has UV protectors. try "clearcoat wing" or something like that. it may be in the how to also. good luck.
oops, just noticed you have an Evo VIII. this should help you out: https://www.evolutionm.net/forums/ev...er-remove.html
There was a thread here a few years back that had pics of a complete wind dismantle. The guy took it apart to take the center piece out.
I have seen all the threads about taking the wing off, sanding and clear coating. But I also know that I saw pics of a dismantled wing with the center piece out. The painted sides come off the wing.
Edit to add: While it might not have pics the thread in the post below you explains the wing comes apart.
Since it might be needed I will just make a thread of my own showing that it does. They say glue though holds the sides on but the thread I seen said Velcro. It might have been that wing had been taken apart at another time prior to the thread I seen.
Raistlin
So after a week of searching I found the thread I was looking for.
The Evo 8 wing does come apart. And it is held together with Velcro.
Here is the thread with the pics and instructions on taking the evo 8 wing apart.
https://www.evolutionm.net/forums/ev...many-pics.html
I found the thread by searching for Velcro.
Raistlin
Raistlin
I knew I seen the thread but I did not think searching Velcro would bring it up (I was wrong lol).
The glue is a pain. I have the bottoms loose but the sides are held pretty tight. After that the Velcro should be a snap. I gave up for today though as my hands hurt and this was not helping them.
Anyway now that I found the thread maybe others can see how to take their wings apart as well.
Raistlin
Bassicfun
Jul 11, 2016 03:23 PM
Raistlin
Jul 27, 2011 04:29 PM
