lost power? :(
lost power? :(
Hey guys, my cars seems to have lost power over night and now feels really slugish this was my setup before hand
JDM evo 8 mr
3" downpipe
3" decat
Perrin intake
HKS J pipe
HKS lower ic pipe
everything was fine with these mods evan unmapped, the car seemed to pull well considering, so anyway the other night i fitted a 3" catback exhaust. took it for a test drive and all was good, seemed to pull alot better. When i hit the motorway i thought i'd give it a lil test through out the rev range to see how it was, 2nd gear was fine and pulled hard, into 3rd and bang!! fuel cut boost spiked to around 1.8 bar. since then there just seems to be nothing really there, like it feels really slow and slugish like its holding back.
any idea's what it could be? the boost guage is still reading boost
JDM evo 8 mr
3" downpipe
3" decat
Perrin intake
HKS J pipe
HKS lower ic pipe
Just curious, why would you suspect a cracked piston, or ring? Compression test?? I think he should look at the obvious first, like a loose hose, or spark blow out.
i havn't reset the ecu by disconnecting the battery yet no. i'll also check the plugs in the morning too, what gap should i be running on the plugs? would you guys recommend putting the stock airbox back in untill i get a remap?
Thanks for the help so far guys, keep the suggestions coming
You can also reset the ECU below/behind the glove box. If you do it that way you do not have to worry about resetting your radio stations or trip meter (if you use it daily that is).
It is the same concept as you remove power form the ECU but it saves you from resetting everything else.
Is your BOV plastic or metal? Have you adjusted your boost any?
Raist
Raist
