Freshly built engine, dip stick got pushed out.
Old Apr 13, 2010, 10:04 AM
05blue8's Avatar
Originally Posted by RockmanX
Yes RockmanX, those are the ones he's referring to
Old Apr 13, 2010, 10:22 AM
lemmysports2's Avatar
Originally Posted by 05blue8
I have the MAP crankcase vents and they did NOT fix my problem just FYI.
you should call map, could you possibly have installed them backwards?
Old Apr 13, 2010, 10:23 AM
rockman knows the deal
Old Apr 13, 2010, 10:25 AM
RockmanX's Avatar
my 2.3 is done just have to install the fluidampr 2 sec job but have never dealt with poping dip sticks etc is it worth the 44 dollars to install this now while engine is chillin??
Old Apr 13, 2010, 10:26 AM
mifesto's Avatar
they also say its because the o-ring is worn and/or to much leftover oil on the side can let it slip also
Old Apr 13, 2010, 11:54 AM
evosam726's Avatar
yeah i hate it when i run high boost then next thing you know i got oil everywhere cuz the dipstick popped off =\ no bueno at all.
Old Apr 13, 2010, 11:58 AM
Ludikraut's Avatar
Zip it!
Somewhat common issue.
l8r)
Old Apr 13, 2010, 11:40 PM
prchico19's Avatar
Mine popped out on the dyno after I had it built. Had the tip of the dipstick tube crimped slightly and I've had no issues since. Recommend improving the crankcase vent system in some way, either crankvents or a well designed catch can system.
Old Apr 14, 2010, 05:48 AM
gamebred26's Avatar
just get a big pair of pliers and squeeze the top of the tube a little...pinch it slightly...it will grab it tighter...
just go a little at a time till it gets nice and night...dont gorilla it too hard right off the bat or it will pinch closed too much...
Old Apr 14, 2010, 12:34 PM
barneyb's Avatar
Originally Posted by vboy425
you have no idea what are you talking about. PCV valve only open under vacuum. When you WOT the PCV closes. That's the way it works.
When it works. It could be full of crud.
Old Apr 14, 2010, 01:56 PM
Ev0ikon's Avatar
A friend of mine pulled the rubber o-ring off, wrapped the same spot with some threads (yes, the normal sewing type) and then slip the o-ring back on. No more popping out the dipstick. If you could get a bit "fatter" o-ring that may help too.
Old Apr 14, 2010, 02:01 PM
evo unknown's Avatar
Would installing a catch can that integrates into the PCV system help resolve this problem in any way? A oil catch can design such as the DC3 catch can?
Old Apr 14, 2010, 02:18 PM
Mellon Racing's Avatar
It's happened on mine one time at 30psi, installed a spring and never happened again even at 45psi. I had a customer lose his dipstick on a high speed run and spun a bearing after losing 1.5 quarts. The rod was blue from the heat. This isn't something you want to experiment with, put a spring on it.
Old Apr 14, 2010, 02:50 PM
Ludikraut's Avatar
It helps, but will not guarantee that the dipstick won't pop out again.
l8r)
Old Apr 15, 2010, 12:28 PM
black E's Avatar
i have one in my car and it has not solved the problem, it pops out at high boost... put a spring and call it a day.
Quick Reply: Freshly built engine, dip stick got pushed out.
