Evo tail light sequence
My tail lights are not working correctly. Can someone tell me which lamps are supposed to be on in the following conditions? I think this is how it's supposed to work.
headlights off, brake on: just the inners lamps?
headlights on, brake on: both inner and outer lamps?
headlights on, brake off: just the outer lamps?
Where should I start troubleshooting if all lamps are turning on, but in the wrong sequence?
headlights off, brake on: just the inners lamps? Outer lamps full power
headlights on, brake on: both inner and outer lamps? Outer lamps full power + inner lamps
headlights on, brake off: just the outer lamps? Outer lamps dim + inner lamps
I believe that is how it should be, but I could be wrong.
Levee06
Jul 17, 2014 12:33 PM
