I want more power.
I want more power.
I own a evo 9 and currently the mods it has are full 3inch exhaust, boost controller and tune. It put down 300whps. i want to add a few things to add some power like intake, fuel pump, so on. Besides those what other little things would i need to add some power. im looking to add only maybe 50 more hps. i would love to have 400whps but i know i cant afford that now.
trust me u dont want e85 on a daily driver because as much as everyone talks about it, its not as easy as said because besides the injectors you gona need to upgrade you fule lines due to the fact that e85 can ruin you stock lines.
Stock lines are fine. Get the injectors(1000cc or maybe larger), a big enough fuel pump(walbro 255), a wideband and a tuner who's "e85 qualified" and you're good to go. Making sure it makes sense as far as the availability of stations that offer e85 that are convenient for you is probably the biggest factor.
But then again you said you(OP) are only wanting 50 more ponies so you may just stick with some of the other mods people have suggested.
E-85
1000 + cc injectors
Fuel pump
Waste gate actuator
LICP
3" full exhaust ( cat delete)
TUNE.
Follow that if you want it nice and simple. You save money and it gets you started.
for now dont worry about big intercoolers or cams...That's $1,000 + for each of those mods and you dont even need them at a basic level. Also dont buy a dumb blow off valve, another waste of money on a stock turbo basic Evo.
E-85
1000 + cc injectors
Fuel pump
Waste gate actuator
LICP
TUNE.
