Where to T in to for LICP?
So i just put my Buschur LICP and Deluxe FMIC on last night. Everything is fine except for i am not sure where to tap the line that is supposed to go into the LICP from the MBC?
So where have yall T'ed off at?
Pictures would be a plus
I know that I'm in a very low minority here, but I installed a nipple in the UICP about five inches from the throttle body. Uses a lot less vacuum line, and leaves the BOV line uninterrupted. No vacuum reaches the MBC, which only needs a boost source. Just my two cents. Good luck.
my car came with the same Buschur delux fmic and j-pipe you speak of. the previous owner drilled and tapped the uicp as lcwjr did due to the lack of a boost source.
now that im running a stock fmic i have no use for the uicp with the nipple on it.. if you interested shoot me a pm and i send you a pic. you can have the uicp for $25 shipped if you want it.
steve
steve
Hey, ill be good for now.
And i need drilling and tapping one into the LICP not the Upper. So if you happens to have the LICP for the buschur deluxe FMIC that would be awesome.
bluegsr
Jul 6, 2010 09:45 AM
Jeff_Jeske
23
Feb 16, 2006 07:37 PM
