at WOT afr off the gauge
started two days ago. normal driving everything runs great...starting in wot 2nd gear after 3000 rpm afr goes high as it can then three dots. is it not getting enought fuel? fuel pump bad?
gt35r
perrin fmic
was tuned las summer for 29psi from buschur but always on the b setting runnig 17-18psi
walbro 255
stock cams
430whp
gt35r
perrin fmic
walbro 255
stock cams
430whp
Yeah either a bad sensor or something is off. Send a log to your tuner and get his impression on it. If he says your tune still looks good then I'd test that sensor. There is a video on how to test a sensor somewhere but basically you put some brake cleaner on a rag with the gauge running and then wrap the rag with the brake fluid around the sensor....Gauge so go from full lean to rich if it is working properly. If it doesn't then you have a bad sensor....you tube the test
good idea on the sensor test
good lookin out every one. i checked the o2 sensor cleaned it up a lil bit and did the test.
took a rag and put some gasoline on it and the gauge did go to 10 and went back down again. so i think its bad but i couple minutes to mess around. did about 3 wot runs 2nd and third was normal.. but im thinkin about ordering the sensor
thx for the help everyone
rrkpitt15
12
Sep 11, 2011 06:59 AM
