turbo coolant flow
Old Mar 25, 2010, 02:40 PM
domantas's Avatar
turbo coolant flow
i just got my theft recovery evo that was missing turbo so i got new turbo in and cranked the car. Coolant wasnt flowing on turbo side. I was wondering if it should or not till it warms up?
Old Mar 25, 2010, 04:12 PM
churbo's Avatar
Not 100% here but I'd assume the thermostat would have to open up before it would start flowing. Don't quote me though it's just an educated guess.
Old Mar 25, 2010, 09:00 PM
domantas's Avatar
thats what i tough, i did not warmed the car up to its normal cause i was afraid of turbo fail. I attached clear tube to make sure coolant flows when car warms up. Any input on routing turbo coolant lines? Upper aluminum turbo hose connects to upper aluminum hose on the head and bottom to a bottom right? Sorry for dumb questions but my car was all srtiped and im almost to the end finishing last steps. If any of you have spare t case, let me know
Old Mar 25, 2010, 10:31 PM
biggie5252's Avatar
I could be wrong, but I don't think turbo coolant flow is affected by the thermostat. I'll have to look in my thermostat housing again.
Old Mar 25, 2010, 11:30 PM
kane.s2k's Avatar
Just in general (and I doubt the Evo is an exception), the coolant does not really flow until the thermostat opens up.
Old Mar 26, 2010, 02:09 AM
pwrofturbo's Avatar
Don't think it does until it warms up.
Old Mar 26, 2010, 08:01 AM
biggie5252's Avatar
I looked and the turbo should get coolant flow at all times and is unaffected by the thermostat. If you open up the housing you will see. Basically everything below the seam (turbo, temp sensors) of the tstat housing will always have coolant flow to it. The tstat determines if it flows out of the upper rad hose (hot) or down through the bottom of the housing bypassing the rad (cold).
If you don't have flow through your turbo, I doubt you have any flow at all.
Old Mar 26, 2010, 08:09 AM
churbo's Avatar
Originally Posted by biggie5252
I looked and the turbo should get coolant flow at all times and is unaffected by the thermostat. If you open up the housing you will see. Basically everything below the seam (turbo, temp sensors) of the tstat housing will always have coolant flow to it. The tstat determines if it flows out of the upper rad hose (hot) or down through the bottom of the housing by passing the rad (cold).
If you don't have flow through your turbo, I doubt you have any flow at. all
Glad you were able to verify this biggie.
Might have bigger coolant problems then just not getting coolant to the turbo. Clogged radiator....clog in one of the hoses....air bubble....ect. Might want to start checking that and let us know what you find.
Old Mar 26, 2010, 08:31 AM
Poik242's Avatar
You won't destroy the turbo just by letting the car warm up.
Old Mar 26, 2010, 11:24 AM
biggie5252's Avatar
True, but he will destroy his engine if there's not coolant flowing through it. If there's not water in the thermostat housing then his temp sensor probably won't read and he won't have gauge indication that his motor is overheating.
Old Mar 26, 2010, 11:30 AM
domantas's Avatar
Ill do a coolant flush and see what happens then. Any input or line routing? The one that comes out from top of the turbo connects to top aluminum hose on head and bottom to bottom? I bet thats the way it is but its always good to double check with u guys
Old Mar 26, 2010, 12:50 PM
lemmysports2's Avatar
domantas- i just tried to take a picture for you, but theres way too much stuff in the way for a clear shot.. my intakes coming out this weekend and ill take some pictures for you if youd like, just shoot me a pm to remind me.
from what i could see the top line coming off the head mates with the front of the turbo and the bottom line meets with the rear of the turbo.
the top line on the turbo is the oil feed and the bottom is the oil return.
this is on a stock turbo evo VIII.
hope this helps and again shhot me a pm if youd like some pictures
Old Mar 26, 2010, 01:13 PM
domantas's Avatar
i would really appreciate a shot. I already have my oil lines hocked up so its good, im only missing coolant hoses.
Old Mar 26, 2010, 05:41 PM
[IMG][/IMG]
the line with the red arrow mounts to the foward side of the turbo
and the yellow arrow mounts to the rear of the turbo
hope this helps, if you need any specific pictures let me know
Old Mar 28, 2010, 02:12 AM
domantas's Avatar
i cant believe someone took their time making a picture for me and draw all the arrows realy apreciate your time, ur awesome!!
Quick Reply: turbo coolant flow
